Old 12-15-2017, 03:56 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
Originally Posted by broadcaster View Post
That set used a brute force HV supply. The transformers were notorious for failing. I converted 2 Transvisions to RF high voltage, using HV unit from junked 7 inch Motorolas. Many of the later Transvision sets used the 7JP4 CRT, which was an improvement over the 7EP4
With all due respect, the most interesting aspect of the Transvision is, IMHO, the lethal brute force supply, in addition to the chintzy 3 and 5 channel tuners, and the AM sound circuit. It's as close to a prewar set as you can get without spending $4000+
I can certainly understand why you would replace the HV supply with a Motorola RF coil. My set will be getting a replacement from Heyboer so I can see how the kit may have worked for the original constructor.
