Old 12-23-2017, 04:14 PM
CRTs4life CRTs4life is offline
I'm not tearing anything up if I can at all help it.
The reference to electron theory vs conventional theory is about the direction electrons flow. + to - or - to +. Convincing arguements both ways.
Anyway,...not that relevant I guess.
I'm familiar with Nichicon, Rubycon, etc. I am a career master auto tech and I never use cheap parts if there is any way at all possible not to.
I bought several of the pre-made cap kits for my old videogame consoles and recently I discovered a depot place in Fla. that sells caps (not cheap ones) in bulk. So I am good to go in that dept. after buying a huge assortment priced right.
P.S.- I will post pix of the Sega running when I get this figured out.
Old 12-23-2017, 07:30 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Ah, an excellent head start there. I hadn't done a whole lot with a soldering iron before starting in TVs. I too avoid any cheap parts like the plague.
Old 01-15-2025, 01:14 PM
Count Zero Count Zero is offline
Hi, did you ever get this EIAJ connector sorted out? I have a Sears LXI model 564-40843652 that I’m interested in utilizing that port for analog video.
Old 01-17-2025, 04:40 PM
Did you ever try this out?
Old 01-17-2025, 08:48 PM
vol.2's Avatar
vol.2 vol.2 is offline
I think you probably missed it, but he did actually reply to this above:
The LXI tv is actually advertised as a tv&monitor. See pic.
And,.... the input is digital rgb, so Sega, etc. unfortunately are not compatible.
So I guess that means it's a no-go. Digital RGB is CGA or EGA (in 15kHz modes) essentially. Can't do NTSC/PAL through that connector.
