Old 12-25-2017, 10:17 PM
Originally Posted by Jon A. View Post
I've seen a bad distributor pickup coil cause that. Often times it was a bear to get the thing re-cranked, not to mention pulling over without the power assist which is probably harder than actual manual steering.
I had an older Dakota with this issue. It would run fine for months, then stall. After it cut out, the longer you let it set, the longer it would run once you started it. If it sat for 5 minutes it would run a mile...but let it sit an hour & it would run another 3 months. Only figured out the cause when it finally quit altogether one snowy day.
Last month I looked at a customer's Grand Marquis; the odometer read around 385k. It was well broken-in!
