![]() I then went hunting with a scope and found a huge 200V triangle waveform at around 15.75 kH on the B+ boost rail. The old 20uF cap still wired in must be dead. I temporarily tacked in a new 22uF and viola - problem solved. ![]() ![]() I have a few more old caps to replace then I'll check the alignment before installing a new 16GP4. Normally, I would do a shotgun recap but I find it can be fun and instructive to do it in stages too. One other thing I've noticed in this and other 1950 era TVs is a weird assortment of resistors. Also some in series or parallel to get the needed value. They must have really been hurting for 1K resistors. A bunch are actually 1.2K and here are two 2K in parallel. They even used a dogbone. ![]() I thought this was a ceramic cap at first, but no, it's a 2.2 M resistor. ![]() I figure the big demand for consumer electronics and the Korean war was causing shortages. Last edited by bandersen; 01-09-2018 at 03:23 PM. |
