Old 01-17-2018, 08:30 PM
Your pics of Archie Bunker and the Oreo are showing exactly opposite problems. Is the width or height (or their ratio) changing with picture brightness? Or different on different sources?
Edit: or did you adjust vertical controls between these two images?
Old 01-17-2018, 08:37 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
No adjustments. The Oreo shows the real problem.
Old 01-17-2018, 08:41 PM
OK. Still asking if it changes with brightness (trying to guess if it could be a regulation problem). If it were my set, I would try replacing tubes in the H and V sweep and high voltage sections first before looking for other problems.
Old 01-17-2018, 09:19 PM
Can you adjust height and vertical linearity to make the Oreo more circular?
Old 01-18-2018, 07:21 AM
compucat's Avatar
1949 Motorola 9VT1
Yes, and in doing so the picture has to be pulled in from the top and bottom about two inches.
Old 01-18-2018, 10:29 AM
So your video source is "letterboxed" 16:9 format? Or perhaps 16:9 format squished to 4:3 (as some of the sub channels do)?
What is the source of the oreo picture ?
Old 01-18-2018, 11:02 AM
compucat's Avatar
1949 Motorola 9VT1
The Oreo is from a commercial on Hulu. I have my Roku box set to 4:3 aspect ratio.
