Old 01-19-2018, 10:48 AM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
The dual use of the cabinet--battery and AC chassis--may explain why I had to raise the "floor" 1/4" to get the dial and control shafts aligned with holes. I'd bet the chassis of the farm set sat 1/4" higher than this one.
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-19-2018, 11:57 AM
It looks like the chassis had some kind of rubber cushion grommets, that crumbled off through the years.
Old 01-19-2018, 12:07 PM
Winky Dink's Avatar
Yes. It was easy to replace the grommets.
Turning to electronics,
Previous suggestion:
"I would break the connection between the plate of the 57 and the 1 meg pot and insert a capacitor there, to take the pot out of the DC path. Likely a .05 would be ok in that location...I would also try a larger value for C-9 for a more mellow tone...”
My reply:
Replacing C9 with .01uF did improve the tone, and replacing R9 with 100Kohms restored the original plate voltage. I also tried putting a cap between the plate and the volume pot, but that seemed to have no effect except to lower the sound level. At this point, the audio is satisfactory.
A subsequent suggestion:
"The way you had the volume pot connected was semi-correct. You need to use a cap .02 to .05mfd between the plate of the 1st amp tube and the high end of the volume control. The wiper would go to C7 and the low end to ground, as you had it. It should correct your distortion problem."
Is this the same as the previous suggestion? The blue is how I wired it before, but noted no improvement and removed the capacitor. So I humbly ask if there is something "semi-INCORRECT" in this picture?"
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-23-2018, 11:40 PM
Winky Dink's Avatar
Finished.
The final configuration is diagrammed above. I don't remember specifically what I used for C-15, but I'm not gonna pull the chassis again to find out. This is what I ended up with after a lot of experimenting. Here's a link to a 13-second audio sample:
https://flic.kr/p/23F6oQ6
I think that's fairly good for a budget radio with a 4-inch speaker.
Thanks again. It's a nice-looking set and it'll be great for listening to the ball game, but maybe not so good for Toscanini. More importantly, it makes me happy.
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-24-2018, 10:53 AM
That's the way I would've done it!
How does it sound with the gain control "maxed out"? The improvements you incorporated is still a great way to increase the enjoyment of this set, even though it's no longer "pure".
