I have a 14" set that does the same thing on a blonder tongue or a NES game. It does work fine however on a VCR.
Noise is RF AGC try it.
Also try turning down the modulator if you can. If not unhook it & put 4' of wire on it & go OTA with it. . It will probably clear up. OR hook a VCR to it. If its not an external problem odds are its the IC. Pins 3 & 4 are used. Pin 4 shows 2 voltages. One is for zero signal the other is strong signal. It should change when mod is switched on & off. Also run the set & see if the IC is getting hot. Should be just warm. You should also check the resistors off pins 3 & 4 before changing the IC. Thats about all I can do long distance, maybe others have ideas. Good luck & let us know how you do. 73 Zeno ![]() LFOD ! |
