Old 02-23-2018, 11:33 AM
Originally Posted by pac.attack76 View Post
I usually don't bother with this cheaper stuff but when I found this set in mint condition in original box, my interest was peaked. Looked like it had never been used. Since then, I have used it to play several cassettes but every time I switch mode over to cd, the cd section never lights up. No power to that area and no movement either. What would cause this? I'm guessing it's a flaw from the factory and it probably never worked. Model number 2320.
You may have a unit that was returned to a local store for the problem you mentioned, although if you say the unit appears never to have been used, I'm not sure. As you said, it could be a design flaw; however, I am at a complete loss to even hazard a guess as to why the CD player doesn't work. If possible, return the unit to the store from which you purchased it and request a refund. These combo units are very cheaply made and do not last very long, certainly not beyond the manufacturer's warranty period.
Old 02-23-2018, 02:45 PM
pac.attack76's Avatar
Stuck in the past
This wasn't a store purchase. I found this among many other things during a clean out nearly two years ago. This things 28 years old so I doubt it would matter anyway. The mode switch works for all other functions, cassette, tuner, etc. I have the original remote which is toast. They left the original batteries to leak and the entire remote board is crumbly. Any leads on the cd player, let me know. I have a meter but forget where I put it.
Genesis does what Nintendon't
