It looks like failing capacitors to me. Have you ever done soldering before? To replace capacitors you need to know how to solder and observe the polarity when replacing electrolytic caps. A $15 Chinese ESR tester off ebay will make IDing the culprets easier. I'd start on the power supply section and see if that does it.
