It happened again. The set goes ‘click’ and the menu stops working then when I press the power button again it goes ‘clack’ and comes back as if the set has just turned on. For the time being, can I turn off the set by pulling the plug after the first click?
Can turning the set off like this damage anything? From what I understand, everything except the tube turns off with the first ‘click,’ as seen in the video, so turning off the set like this is ok? https://youtu.be/ke62Pw5Leck Last edited by Outland; 03-27-2018 at 06:52 PM. |
