Most sets if the relay sticks when you turn off most of the
micro is turned off & is only waiting for another ON command. Therefor no channels, OSD etc. Other possibility is the relay is only a degauss relay & ON/OFF is done another way. Usually by turning ON/OFF the horz osc. Best test is a new relay. Any with the same coil voltage from almost any TV will work. You may have to extend terminals with wire. Some sets are even drilled to fit 3 different styles...... 73 Zeno ![]() LFOD ! |
