Old 03-29-2018, 01:26 PM
1.662 volts with the grid of the 25L6 disconnected? That's quite high! Was there anything at all connected to the grid pin? For example, just a short clip lead will pick up a significant amount of hum.
Do you measure the same voltage with different 25L6s?
There was nothing on the grid pin when I measured at the speaker leads and got 1.662 volts ac.But I did use a clip wire to measure the grid with the wire on the grid. 25l6s the same. I've been going over this beast and can't find a thing out of place.
