Old 04-08-2018, 04:28 PM
Primary to secondary leakage in the blocking trans could cause bias issues...Shorted turns could detune the frequency and suppress oscillation. Did you compare tube/schematic voltages in the vert stage yet?
Old 04-08-2018, 04:45 PM
Blocking xfmr was my first thought, once he got sweep by injecting at the osc. grid.
Old 04-08-2018, 06:37 PM
It was the blocking transformer! I had another one here and put it in. Bingo!
Thanks for all the suggestions.
Old 04-08-2018, 07:37 PM
Old 04-08-2018, 07:50 PM
Can you measure anything odd on the bad transformer? Seems as if we have seen several now that have appeared to be good, but did not function.
Old 04-08-2018, 08:28 PM
I measured the leads each other and to the case. Everything seemed good. I then hit it with my heat gun and got this:
Yup, a transformer! I ohmed out the windings again and the values crept up from pri-1130 to 1533, sec-153 to 173. I also checked for shorts between the leads and shorts to the core. All seemed good.
