This also provides a bit of hope to anyone with a rather anemic looking 15GP22, provided of course it's still under vacuum. |
These are simply quick shots with my iPhone. I guess I got a little lucky with the lighting level. I didn't have to adjust the brightness up or down from normal viewing for those shots.
Anyone have any idea why I'm seeing the screen voltage behavior I mention above (red is stronger at low screen voltage, not higher)? I wonder if the higher screen voltage is throwing off the purity? Wouldn't really seem to make sense that it is actually lowering the emission... |
so bad it destroyed itself (and then arcing became almost continuous). The theory is that the center of the cathode is completely dead and the emission from the outer ring is, with the screen at normal voltage, hitting an electrode before it gets out of the gun. When th screen is lower, the focus changes and the electrons get through. This is of course a very far-out idea. It could be tested using an electron gun field simulation program, if we knew the geometry, or by examining a gun removed during a rebuild. |
I've seen this effect blamed on a dead cathode center region in period papers. It's possible the same effect that causes this behavior in B/W tubes is causing the strange behavior of Tom's weak red gun. |
just a WAG, jr |
I think you're on the right track. Now that I've modified the screen control circuitry so that the adjustment range of the screen controls is at a little lower voltage, as I go from the lowest screen voltage to about 1/3 the way up, red brightness increases. Beyond about 1/3 up, the red brigthness decreases, and near the top of the range, I think the entire picture (all guns) is defocusing a little. This might be consistent with additional current dragging down the voltage on either the first or second anode, without additional beam current actually making it to the screen (it's hitting elements within the gun).
I don't think I'm seeing a bigger spot size on the red. Picture is pretty sharp overall. Don't know if that's consistent with the idea that the center of the cathode may be worn out, but I'll simply report what I see. Last edited by Tom Albrecht; 05-27-2018 at 11:29 PM. |
Tom, I know that I am late to the party. I did see the pictures that you posted a few days ago. Just wanted to say how wonderful it looks. I must admit that I only recently became aware of the 15GP22 CRT thanks to this forum and the Antique Radio Forum. I will admit to having never seen a real 15" color set (vintage that is).
Very Nice! |
