Old 07-17-2018, 09:36 AM
Best bet with wet sets is dry them off fast. Open them up
& use a hair drier.
For the set in question a pic is worth a thousand words.
Old 07-17-2018, 08:18 PM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
& use a hair drier.
yeah you're right . I forgot to say it . .
Old 07-18-2018, 12:29 AM
Sealtest Sealtest is offline
The hairdryer method is what I use along with a fan. Ive gotten way too used to having to dry out all sorts of electronics. Everything from TVs to macbooks.
Hopefully my pictures attached. I haven’t had much time to Mess with this set since I’ve been trying, and failing, to get some 50s tube sets going.
File Type: jpg 50F00702-479F-4B59-9C03-A56987D98C26.jpg (35.4 KB, 40 views)
Old 07-18-2018, 07:11 AM
horz hold is off. IIRC its a coil so you may have to go beyond
a stop. Turn direction of less lines til the pic pops in
Old 07-18-2018, 10:14 PM
Thank you! I will have to clear a spot and try to adjust this some more. Did the hold fail because caps have drifted to other values possibly?
Old 07-19-2018, 08:05 AM
Could be drift or if any little kids were around they may be to blame.
Even adults would mess them up. We used to get tons of them in
back in the good times. Since we ran up to 3 weeks behind if I
thought that was it I would quickly adj it & send it home. Very few
came back. All done for free.
Old 07-21-2018, 07:53 PM
Thanks! I just took this tv back apart and took it into the shop. I did exactly what you said (plus adjusted the vertical height) and it actually looks like it is now working with a Bar and Dot generator. It still needs a different input tested with it and it really needs the controls cleaned, but after that it will hopefully make a nice little tv.
The only thing i don't like is how this tv does not have a focus control. That may or may not be an issue, but that will be determined later.
