Other Problems
I don't think I quite understand what your doing. Isn't the deflection on an old Sinclair TV magnetic and I believe the pilot used electrostatic. I would think the biggest problem would be the horiz and vert scanning not the heater voltage. How did you solve that problem?
Thanks, Dennis |
Just wanted to add that I would still mask the CRT in a smaller "double-D" style. You'll only lose a little bit of the edges of the picture, but it will look a whole lot more convincing. With construction paper it would be easy to make either the early white mask or the later black and gold pinstriped mask. Good luck!
I would agree. There's still many of those Pilot TV's around in various states of repair. You might try to nab one with a rough cabinet for a reasonable price and hope the CRT is good. I know someone who haggled for a very nice one at a local antiques shop recently - he got it for $75! - and it turns out with a good CRT! That's about the only way to get the original white CRT these days, or even the green substitute, which is acceptable.
What if you put a red filter in front of the 3kp1?
