It wouldn't surprise me if a foil/paper tubular cap in the vertical circuit shorted, causing overvoltage (ergo overcurrent) through the resistor.
Just a guess (Many other possibilities) |
There is an electrolytic on the cathode of the vert output that
causes the bottom to pull up. Eventually the vert should be recapped except for the discs. Also the 3 legged integrators changed. Check all resistors especially high ohms ones. Do recapping one at a time then test to be sure of no mistakes. These will be of interest........ https://www.youtube.com/watch?v=vt7OLBCoR8o https://www.youtube.com/watch?v=6lZIJQ-cKDs&t=141s 73 Zeno ![]() LFOD ! |
