Old 09-20-2018, 07:45 PM
For a quick test you can tack a second 3.3 ohm in parallel. That way you'll save all the work of removing the original in the event that it makes no difference. However there's also the concern of keeping the solder joins round and smooth in that high voltage area. Sharp points are more prone to arcing.
Old 09-22-2018, 01:23 PM
Zsuttle's Avatar
Zsuttle Zsuttle is offline
Well, I was able to get a pretty decent picture and did my best to adjust it. Is the ion trap supposed to be so close to the focus magnet? The only way I can get a picture is either pushing it right next to the focus coil or almost to the end of the neck. I thought it was supposed to be midway on the tube.
I had to order the resistors because I didn't have any that low.
Thanks for everyone's help so far,
Zach
"If it isn't broke, you aren't trying hard enough"
