Old 11-28-2018, 06:26 PM
zombie1210's Avatar
zombie1210 zombie1210 is offline
I know nothing about this model. Never seen one before and there doesn't seem to be much info floating around about it.
Old 11-28-2018, 08:50 PM
It looks like a good find, I have a weakness for a radio using a 6B7 as a first amp and detector. Wells-Gardner used it in several models as well.
At least, it doesn't use a resistor line cord, but it does use a few octal tubes.
Old 11-29-2018, 10:18 AM
It just dawned on me, ST. Regis was a Rexall drug store brand. I've seen inexpensive wind-up alarm with that branding.
I looked up the schematic and it uses a 3000 ohm field coil connected across the B+ instead of being used as a choke. Circuit is a bit more interesting than the average set of it's day.
Old 11-29-2018, 12:18 PM
International Kadette evolved into Detrola Corp later.
Most of the products they built were private labeled products.
