Old 01-11-2019, 07:46 AM
jbattles's Avatar
jbattles jbattles is offline
jbattles
check your delay line
Old 01-11-2019, 09:45 AM
You may try lifting pin 12 & see if you get 1-2V P-P of video on the
pin. You could also try hooking in composite video at TP 6 from a DVD. Just
be sure to use isolation !
I just dont see having a run of bad ICs but its not impossible.
If it were an expensive power pack then I would suspect bootleg
Chi-Comm crap.
Old 01-11-2019, 10:36 AM
Jeff Jeff is offline
Just for good measure, I replaced the IF amp IC again, this one was a completely different brand and seller, and it does the same thing. Pulled pin 12 and there was just a flat line all the way down to the 100mv range. The thing is, when I inject a composite video signal straight to the video amp, It basically does the same thing with it's color situation, but I just assumed this was because composite is only 1v pp and the circuit expects 2v pp.
Old 01-11-2019, 10:31 AM
It measures around 60~ ohms or so, with no shorts to the 22v rail.
