Old 01-24-2019, 03:32 PM
Tom OM
I gave up on OTA. With ears I only get one station & one other sometimes.
In NTSC days ears would reach out over 100 miles. A big antenna would
get ME, NH, VT, RI, MA, Conn & at nite NY, NJ & PA. all from the average
elevation. Well thats progress ? ........
You know what they say "if its digital its got to be good".
Get a Zenith DTV converter box go into the menu manually tune the carrier observe the OSD signal strength meter while peaking the antenna then transfer the antenna back to the crappy internal one in your TV.
Old 01-24-2019, 04:19 PM
Tom OM
I miss NTSC too...We are probably in the company of most of VK on that.
I'm mostly cable and internet on TV viewing, but I like to DX and play around.... also the family cabin only has access to OTA so I had to get good at grabbing weak signals.
That cabin is so far out in the boonies that the girl who the news says was adbucted and held captive for months was being held a few miles away from there.
Unless you have VHF DTV carriers or are not far enough out to qualify as fringe, rabbit ears are not much better than a foot of random wire jammed in the center of the ant jack...If you want an indoor DTV UHF ant go with a 70s bowtie chop the twinlead off and solder a balun to the feed point with the shortest leads possible.... I was able to best a new expensive amplified antenna relatives bought for the family cabin by a good margin with that 2 buck rig.
BTW if OM was supposed to mean old man I'm still a long way from reaching that title.
