GE 806 - Volume / Focus potentiometer help!
Hello, everyone,
I am in the process of restoring a GE 806 10" tabletop set. I'm almost done with the restoration, but the volume/focus potentiometer is bad and I need to find a replacement. The pot is a 100k/500k dual concentric pot with a power switch. Does anyone have a spare parts chassis or pot of this type or know where I could find one? I was able to fix the focus (100k) pot to work with carbon paint. It's not perfect, but it works. The volume pot (500k section) is too far gone, though and I am either getting full blast volume or nothing. Thanks in advance for your help and recommendations. If more information is needed, I am glad to provide. I appreciate the help! |
You're in luck.....I have a whole front control panel for one, controls intact. PM me your address and I'll send you the volume/focus control
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
Anyone have the similar (but not identical) control for a GE 810? On the 810, the volume/power control is one unit, and a concentric hollow shaft with a pulley drives the focus pot mounted above.
Phil Nelson Phil's Old Radios https://antiqueradio.org/index.html |
This forum is awesome! PMed you, Kamakiri. I really appreciate the help.
I'll post pics when it's all done! :-) |
Hello, everyone!
Tim kindly looked for this part for me, but it wasn't good. Does anyone else have any recommendations for finding this for my GE 806? I really appreciate your help. |
![]() I hope something of that can help. The larger resistor has a 6mm/10mm shaft, the smaller has a 4mm/8mm one. I have a plenty of them on hands, and can re-assemble any one with the required resistance combination.
To understand a bygone era, you should use things from it Last edited by Gleb; 01-28-2019 at 04:04 PM. |
Thank you for your reply, Gleb!
The inner control is supposed to control a 500k pot for the volume and the outer control is supposed to control a 100k pot for the focus. Do you have something that would fit that description? I'll have to measure the shafts on the originals - I doubt these would be the correct length, but maybe I could fabricate something to work. I appreciate your help and will of course pay you for your time, the part, and shipping if you find something that can help. Thanks again! |
Have you succeed with Mark Oppat? If not, my offer is still valid.
To understand a bygone era, you should use things from it |
