Old 01-25-2019, 11:30 AM
RadioTVNut00 RadioTVNut00 is offline
Zenith Royal 64 no power
Hello. I have a Zenith Royal 64 all-transistor radio that I bought in the summer of 2017 for $10. Recently, I have turned it on and haven't gotten anything out of it. Could you help me diagnose this problem? I tried new batteries and same result.
Old 01-25-2019, 03:08 PM
A few easy things. IF the radio is stone cold dead plug an ear phone in.
If you get sound its almost always the speaker.
Check the battery box for corrosion & broken wires.
ON/OFF switch. There are 2 wires on the rear of it. Put another wire
between them & see if it comes on.
Beyond that you will need a schematic, multy meter & luck !
When looking for the schematic use the CHASSIS number. Its on a tag
inside the radio.
Old 01-26-2019, 10:06 AM
If that Zenith is anything like the Royal 66, it uses a dual switching arrangement. It has four wires on the switch and uses a tapped power supply.
Old 01-31-2019, 12:50 PM
Zenith Royal 64 Pictures
Here are pictures of the Chassis and battery box. The chassis number is 8NT45Z8.
Old 01-31-2019, 07:59 PM
It's located in Sams TSM73. It looks like it runs on 2 "D" cells, 3 volts.
You'd have to see if anyone has a TSM73.
