I don't know exactly about US-made sets but I met 'ohmic' HV heater windings in some early Russian televisions. Just a precaution to be sure that it's not your case.
To understand a bygone era, you should use things from it Last edited by Gleb; 02-08-2019 at 05:18 PM. |
Mine uses wire. It does use a 3.9 ohm resistor. Which was replaced.
Today I tackled the HV cage mod. I cut away the corner and made a triangular filler piece. Then cleaned it up and painted it a silver color. I wanted it a bit different color than the chassis.
I then finished up wiring the HV cage. I replaced all the HV wire, except the HV lead to the CRT. Then I could finish up wiring in the Yoke wires. All done except the 300 Ohm twin lead from the Tuner to the terminals. Then on to first power up. ![]() ![]()
