Old 04-16-2019, 03:13 PM
Rocket's Avatar
Rocket Rocket is offline
VideoKarma Raccoon
Yes, I DO have that one, which I have removed for the time being , was not easy... took a LOT of heat!
Sent out them templates to ya today ;D made a few extras also Incase one gets messed up
Old 04-16-2019, 03:19 PM
tks
I was thinking of making it out of something like...
this
http://tinyurl.com/y5eo2u9t
Old 04-16-2019, 04:06 PM
tks
this
The original was thin sheet steel which you can get at ACE, Home Depot, and other places... Metal shears, files, drill bits and a stepped bit or chassis hole punch are all you need to duplicate most of it... the spring you'll have to get creative with.
Old 04-16-2019, 04:18 PM
Rocket's Avatar
VideoKarma Raccoon
Yeah np, and drill bit for the small holes and a step bit would be great for the larger ones indeed
Old 04-16-2019, 07:16 PM
my newly repaired TV pattern generator
https://imgur.com/NpSGacg https://imgur.com/6rqrmoB https://imgur.com/2R9DUWh
which had 3 fried resistors, I think my dad did something stupid with it :/ ( he built it after all ) so I took a guess on the values
i now have an input source, other than an old VCR... :P
Old 04-16-2019, 07:48 PM
Rocket's Avatar
VideoKarma Raccoon
that's pretty awesome!!
Old 04-17-2019, 06:52 PM
being tested after the latest round of resistor replacement. ( with repaired bar /dot )
https://imgur.com/dVAV4Yw https://imgur.com/MWQ3jYw
Also a shot with the chassis in " service " position
Old 04-17-2019, 08:12 PM
BTW: RCA color with separate tuner chassis tip: the tuner sub-chassis should have two half-moon tabs on it's chassis a distance away from everything that seem weird and pointless...Those tabs screw down to the main chassis (IIRC on either side of the interlock) securing the tuner to the main chassis in the factory recommended chassis out service position...
It took me a while to figure that out on mine and in the meantime that cables flexed so much that wires broke off tuner chassis terminals causing more work for me (the tuner IF coax was among the more annoying repeat breaks)...Don't follow my initial bad practice.
Old 04-17-2019, 09:01 PM
Rocket's Avatar
VideoKarma Raccoon
it even looks like we have the same cabinet! the harper from 1966 I believe.
Check out the 7th page down : D
http://www.bretl.com/tvarticles/docu...uyersGuide.pdf
Old 04-17-2019, 09:25 PM
Rocket's Avatar
VideoKarma Raccoon
hmmm maybe you actually have the Suffolk
Old 04-17-2019, 09:40 PM
yeah, that looks like it,
$500 in 1966 = $3600 now
Old 04-17-2019, 11:07 PM
Rocket's Avatar
VideoKarma Raccoon
Yeah! isn't that crazy! I think you could buy a car around 2k or so
Old 04-18-2019, 06:16 PM
OK... I get SLIGHT color rainbowing when i try to get the color bars to show up via tuner.
but I still DID get that blue color screen from the VCT to show on it when i injected video at 1st video amp. ( this was something I never did when I first got it, and falsely thought it was a bandpass failure )
this weekend will start to attack the IF section resistors.
Old 04-19-2019, 05:06 PM
they arrived today!! =^-^=
Waiiiii!
Old 04-19-2019, 09:31 PM
Rocket's Avatar
VideoKarma Raccoon
Waiiiii!
Whoot!
