Originally Posted by Bill R
Do yourself a favor and resolder ALL of the points where that circuit board solders to the chassis. These are used for ground connections and will cause all kinds of strange problems. Use a higher wattage iron so you can get enough heat on the chassis stake.
As i mentioned earlier in the thread, some fool REMOVED this PCB, and I replaced it when i got it, so they have already been re soldered.
the handy weller 8200 i got from my dad did nicely for soldering the gnd points :p
