I blew up the gas tank.
The EVAP system has been gradually repaired as when I got the car it didn't work at all and on Saturday I finally replaced the gas cap and the system pressurized normally again.
However in the past at some point after it had failed the tank had developed leaks and was patched with putty and now that everything was under pressure again it promptly began weeping fuel out around the patches. Tank rebuild is $450, but a new OEM tank is $155 plus shipping. Guess what I'm doing.
