There is no one stop source. OEM manuals are best. Sams may help.
Internet may also. Many settings are feature level or mode. Also stuff you would never have to change. Usually important adjustments are labeled or in the manual. Others are a default for area such as US / Canada etc & will kill the set if changed. Best advice is....... ALWAYS write down a full list of settings BEFORE you make any change. Often you have to exit the menu correctly or the changes will not be written in. Menus are often 2 or 3 deep so you need the right password to move to the next level. HAVE a working OEM hand unit if at all possible & CAREFULLY follow the OEM instructions ! These settings almost never need changes unless corrupted or you change an E-prom etc........ 73 Zeno ![]() LFOD ! |
