I had to look at the alignment instructions for this chassis and yes you are correct. That coil, although part of the tuner, is actually on the IF side so yes, it would be part of the procedure since it's really part of the IF strip. I'm guessing its response is a bit more broadband than the other adjustments.
Erich Loepke |
