A few notes on all of this.
Econoquick is just a fast warm up CRT. No STBY voltage. Almost all SS sets WITHOUT a power transformer use a flyback (FBT) winding for the CRT filament. Some sets ground on end & others "float" it at apx 130V. This is to keep the F & cathode close DC wise to reduce arking & H-K shorting. Service notes. Always look for cold joints especially if the set has a PCB for the CRT socket. Early RCA in line CRT sets used a spring contact socket. Many had toasting & went intermintant ( RCA, Admiral, Maggy, Sears/Warwick ). The plastic key on the CRT would melt & the contacts burn. Repair was a new socket, remove key, clean & bend F pins out slightly then put the key back on. Sets with H-K short & grounded F. There was a rash of Sanyo built Sears with Sylvania jugs that shorted H-K. This coinsided with mass failures of the Z0064 HV rect, divider that kept us quite busy ! They used a grounded F configuration. Repair was to isolate the F from ground ( cut etch & run a wire). Place a 1.5 meg resistor between the shorting K & f. Also add IIRC a .01 cap from the K to ground. This made the set usable again but you could still see when it shorted in the pix. $50 sure beat a new set for the customer ! Low E. Caution some risk !!! You should use a scope for this ! Measure the P-P filament first. You want to increase the F about 20-25%. Most sets have a low value resistor in series with the F ( apx 2 ohm 1 W ). Jump it out & watch the scope for the change in P-P. Early sets had an "open" FBT with the core for the pulse winding exposed. Try adding a turn to the F winding. Use the scope to watch the P-P. Again not a perfect solution but sure beats a new CRT ! Instant on. One of my biggest beefs. Instant on is a killer especially on all tube TV's from all MFG's. All of us are quick to condemn it. BUT on SS sets its a different story IMHO. Ask anyone here what CRT holds up best from the 70's. 90% will answer Zenith chromacolor jugs. The flat chassis & E line CC2 sets both had instant on............ I am tired, nuf sed fer now 73 Zeno ![]() LFOD ! |
