If the tubular caps are original order those too at a minimum (parts to rebuild the K networks/couplates and resistors for the mainboard are also advisable).
Those plastic-bodied caps leak current (which is probably what is wrong with the vertical) bulge/crack then smoke and or explode...I just did full and partial (if I plan to sell a set for whatever I'll get paid for it I don't throw much money at it) recaps on 2 10L43 predictas and both had either cracked bulged plastic caps on the board or developed them in under 10min of operation...
caps
I will end up replacing everything that is out of spec, I don't plan to ever part with this set. What concerns me the most is the condition of the flyback. It is not arcing or anything, but the wax is cracked. I wonder if I can just re-coat it? Oh and I noticed tonight that the "Philco" label on the front is not missing, it just has some tape covering it. |
When you get a good chance to upgrade to a nicer specimen on the cheap why not?
Some day
![]() I really wanted one of the barber pole ones, but this one came up at a great price and I could not pass it up. Normally they cost an arm and a leg for "untested and molested". I can see parting one out if the cabinet is not nice. If I run across a NOS CRT or even another set... I would get it for spare parts. Once I get it restored, I will use it but not daily so I figure it should last the rest of my life.. |
I'm surprised someone hasn't jumped in with 'Re-coat it with corona dope' yet. So far I haven't had to do that, so I have no personal experience of it. Personally I would fix everything else before I did that - those fine wires coming off the transformer look very delicate.
http://nixies.us/ |
