Nope. T6 is the focus coil and it's mounted on the neck of the Picture tube. L1 is the small transformer(choke) mounted under the chassis as I have it marked.
Dude, take a deep breath and just clip the wire goin' to pin 2.
Now, measure from pin 2 to ground. If infinite resistance (open circuit), tube socket and power xfmr are not suspect. Short is 'downstream'. |
So where should I check next? |
