OK so a little update, I powered on the set with all but the H. V. Rectifier tube removed from the TV and the TV's current draw leveled out at about .39 Amps or 7.3 watts according to my Kill-A-Watt Meter, which is fairly low.
So I'm guessing that the transformer is actually fine yet and my problem is just a bunch of paper caps that have shorted to ground somewhere in the TV (more than likely the two .01 MFD caps on the AC line for noise supression are the ones to blame because they are soldered to ground on one side and if they've shorted, they've more than likely shorted to ground.) Last edited by vortalexfan; 10-07-2019 at 11:22 AM. |
Scratches head... how does 122 Volts @ .39 Amps equal only 7.3 Watts?
![]() jr |
Just measured an unloaded tv power transformer of similar size on a kill-a-watt meter, readings were: 122 Volts, 0.26Amps, 9 Watts, 34 VA, 60Hz, 0.28 PF (power factor), so I believe that the PF could be as low as 0.15. ![]() Did you happen to get a power factor reading? jr Last edited by jr_tech; 10-07-2019 at 03:03 PM. Reason: add question |
123.4 Volts AC 0.40 Amperes 8.2 Watts 50.6 VA 60.0 Hz PF (Power Factor) 0.16 Hope this helps. P. S. depending on the time of the day my voltage readings coming out of my outlets can range between 119.8 VAC and 124.5 VAC, when I took my Kill-A-Watt Readings just now my Voltage reading was 123.4 VAC when I took it this morning it was 122.5 VAC. Last edited by vortalexfan; 10-07-2019 at 06:46 PM. |
So, because of the low power factor of the unloaded transformer, the .40 Amp current draw does not appear to be excessive at all. Your transformer is behaving much the same as the known good transformer that I measured and is probably good.
jr |
So it definitely means that more than likely my problem lies with some bad paper caps in the TV that have shorted to ground more than likely. Probably more than likely one of the paper caps that I have yet to replace. Which I have already replaced almost half the capacitors in the set already, I have about 23 more capacitors to replace in this set yet (that includes some of the electrolytics that I haven't replaced yet in the set). |
