Old 10-15-2019, 11:35 AM
freakaftr8's Avatar
Convergence freak!
Loosen the lock down clamp from the rear of the yoke and push the whole thing forward to the bumper stops. There should be 3 wedges.. One on the top center and two on the bottom all spaced evenly. Once you do this, you will probably have to turn the yoke a tad to correct a tilted picture. But should fix your problem if the wedges haven't physically came unglued from the crt and moved.
Another way to do it would be to physically remove the top wedge and while pushing the yoke up from the bottom put the wedge deeper into the void there to sustain the yoke angle
