I overcharged my truck and it dumped some oil out of the rear seal of the A/C compressor, right on the intake manifold, a stinky mess! I've never heard of oil leaking out of the evaporator side, but it's certainly possible
An oil leak that large should give a LOT of noise as the AC system vents. Are you positive the AC still works?
When you mention a T-junction though, I know some vehicles (my eagle included) shared the heater core in the same cavity as the evaporator and thus used a bypass valve to shut the heater core off whenever the AC was turned on. Due to the high heat and the mechanical nature they are famous for leaking. Edited: one other thing. Are you POSITIVE it's not just condensation dripping off the evaporator? It is Arizona but one good rainfall is enough to crank the humidity up to 80% for an afternoon. Last edited by MIPS; 10-21-2019 at 11:05 PM. |
Eh, it's possible. I've seen a few evaporators fail in that manner. They leak just enough to get the oil smell through the vents when running the a/c, but slow enough that the a/c works at least through a season. Last edited by MadMan; 10-22-2019 at 10:32 PM. |
