Well the only thing different was that the tubes were installed in the tuner when I took those measurements of Pin 8 of the 6V6 and input and output sides of R13, other than that nothing has changed circuitry wise in this TV.
I don't see a problem with the voltages you just measured, but they don't seem to line up with what you reporting earlier with the un-tubed tuner socket pin voltages being so low.
I ask because I have been subbing a 6AK5 in place of a 6AG5 tube in the tuner and I wonder if using a substitute tube rather than the original tube that it calls for in the circuit could be causing my tuner not to work right... ![]() I know the tuners in these early TVs were quite finicky about how they worked. |
As for testing the tube socket voltages, I'll do that again and see what I get, which pins should I test? |
I meant they show a 6AK5. For starters just measure the plate pins, that's where we're looking for B+.
While you're at it try turning thought the channels and see if that changes the voltage. I just looked back at your earlier photo and that tuner has a major rust deposit on top. If mice were peeing on it, it could be there's a real mess down in the contacts.
Also checked the voltages from the top without the tubes in and they were spot on to where they should be, on pins 1 and 2 of the 6J6 socket I was getting around 193 volts DC, and pins 5 and 6 of the 6AG5 socket I was getting around 193 Volts DC as well, which I think will drop down to the readings on the voltage chart when the tube is in the socket. Also I think I might of figured out what's going on, a couple of the center pins on a couple of the 6AU6 sockets broke off on the bottom of the Chassis, one of them is in Video the IF Circuit the other one is the Sound IF 6AU6 socket. |
