Old 11-11-2019, 11:06 PM
Originally Posted by vortalexfan View Post
Why, am I not supposed to be getting 193 Volts there?
The sams schematic and voltage chart don't show anywhere near that voltage on those pins. Also as I mentioned before, the schematic shows the tuner b+ being fed by R13. If you had 158v on the input side of R13, and 154 on the output. There is no way for that voltage to increase on the load side, because the more current you pull thought that resistor, the lower the voltage will go on the output side.
