Here's where I'm at now, see picture below. I still can't seem to get the picture to fill out the rest of the screen, as you can see in the picture below the screen for some reason won't fill out the upper right hand side of the screen, and I'm still having problems with the jailbars on the left side of the screen and the top of the screen is all stretched out looking and the bottom part is normal looking.
Vertical not filled and non-linear: put a test pattern (in a pinch end credits with even spacing between lines when viewed on a better set will do) on screen and adjust vertical height and linearity simultaneously (may need to juggle vertical centering too)...If you can't get a full linear vertical sweep check resistors I the vertical. The left vertical lines are probably horizontal drive lines...try adjusting horizontal drive...If that don't do it your probably going to need to adjust the horizontal osc waveform with an oscilloscope.
Another possibility for neck shadow is not having the yoke all the way forward to the bell of the picture tube. Sometimes slight adjustment of the ion trap will do it too, but don't compromise your brightest screen setting just to eliminate a shadow. You're in the home stretch now.
but none of that made any difference as there is still "shadowing" as you call it going on in the picture tube, no matter how I adjust the Focus Coil or the Yoke. |
Can you post a few pictures showing how the yoke and focus coil are positioned relative to the picture tube? A side, rear, and top view would be helpful. Tom mentions tilting the focus coil, but if you have wing nuts that allow forward/reward, as well as up/down, all those movements can affect neck shadow. The electron beam is basically looking down the barrel of the neck, and if it's not bent to center by all combined adjustments before it clears the bell of the tube you'll get a shadow.
Unfortunately I'm afraid that 1 Meg 1 Watt resistor that was in series with the high voltage anode to the picture tube might of finally bit the dust as no amount of adjusting the ion trap is bringing back the picture, and I think the resistor was slowly dying because I started out with a super bright picture and it gradually got dimmer until it finally went completely dark. |
Easy enough to change that resistor, I suppose? |
But now I can't get the screen to fill out horizontally, for some reason or another I can't get the horizontal linearity and Horizontal Size adjustments to do anything to the screen as far as resizing it goes. Last edited by vortalexfan; 11-12-2019 at 10:17 PM. |
