Old 11-22-2019, 09:24 AM
CRT probably woke up from sleeping sickness.
Those thermistors were designed to get hot and often would unsolder at the point the leads joined the resistive puck... Sometimes the pucks would crack too. These were high failure parts in color TVs (which was the main application for them).
Check the brightness pot and if it is good change any caps in it's circuit that might be leaky and dragging it's output.
Old 11-22-2019, 09:50 AM
Ok, thanks, I'll check into it.
Although this set has mostly Mylar caps in it except for about 4 paper caps that I saw on the back of the set so it seems that there shouldn't be too many caps needing changed in this set.
