Old 12-27-2019, 05:24 PM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
I think I figured out the vertical issue. I was using a different video source when I adjusted the geometry, and as it turns out some of the black and white broadcast shows I'm watching have significant variance in the darkness between shots. I'd already discovered that the vertical on this set can get touchy when the brightness dips suddenly, and apparently it was still doing that. So I played with the vertical linearity a bit more to find a happier balance. That seems to have fixed it.
Just need to get that slat fixed and I'll be done.
Next up is a small adjustment to my RCA 8-PT. I may not need to make a thread on it, but I'll see about posting pictures at least.
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
