Thread Tools | Display Modes |
There is one born every second! Then they make a glorified Chevy pickup with the Cadillac badging that has to be registered as a truck. I don't think that you can buy a Cadillac passenger car that has a V-8 engine.
I know. There's nothing wrong with wanting a simpler vehicle. Depending on the year used escalades aren't much more complicated than a Yukon Denali. Given even my simple suburban has needed it's fair share of of maintenance on all fronts stuff will need to be fixed no matter what you drive. The nice thing is the common parts on the drivetrain and chassis of all vheicles in that family are pretty good solid designs...the luxury features I don't regularly use or need to use can sit broken till/if they ever become important enough to bother...my suburban came to me with an AC leak that would bleed it out in a week or two. Being used to Florida summers but living in Wisconsin now I only would charge the AC for long hour+ drives or on the worst day(s) of summer (windows down is usually all I need to feel fine) and 3 years of using 134 with stop leak has gotten it to the point it will now hold charge for months. I honestly don't know if the rear headphones based radio even works since I never had a desire to use it.
Getting almost) back to the subject of this thread, I'm surprised that I haven't seen much mentioned in the way of pushbutton controls for the early automatic transmissions. Here's the unwieldy-looking button panel for the mid '50s Packard Touchbutton Ultramatic:
First Row: Neutral, Low, High Second Row: Park, Reverse, Drive Probably the most famous was Chrysler's pushbutton-controlled PowerFlite and TorqueFlite transmissions, offered between 1956 and 1964. Here's the button panel from a PowerFlite-equipped car: ![]() (the parking brake was engaged using a separate lever) Less well-known was the Teletouch system used in the ill-fated Edsel line. Inexplicably, they chose to place the pushbutton controls smack dab in the center of the steering wheel, which probably caused some interesting transmission acrobatics when someone not well-acquainted with the system tried to honk the horn as you would on most other cars. Here's a photo:Closer view:
Visit my site! Stereo: Pioneer SPEC-4, Pioneer SPEC-1, Kenwood KT-7500, Dual 1219, Nakamichi BX-100, Pioneer PD-M60, Paradigm Studio Monitors |
![]() The Edsel used an electronic pushbutton system and supposedly some cars developed steering dependent shorts in the shift wiring causing the transmission to freakout on turns...That had to be fun. Chrysler used a standard shift cable with the push buttons pulling the mechanical shift cable to the same points a shift lever would. It was a very reliable system from what I understand. Mopar had atleast one other bezel and button mech during their pushbutton automatic days.... one of my favorite big fin cars is the 60 Plymouth Furry and they have the that other style. Coldwarmotors on YouTube rebuilt the pushbutton mech on the 60 furry he is splicing together.
![]() Quote:
![]() ![]() Quote:
Visit my site! Stereo: Pioneer SPEC-4, Pioneer SPEC-1, Kenwood KT-7500, Dual 1219, Nakamichi BX-100, Pioneer PD-M60, Paradigm Studio Monitors Last edited by AdamAnt316; 07-21-2020 at 02:08 AM. Reason: Just had to add that mask.......... |
