Old 04-01-2020, 09:57 AM
You could sub in ceramic as a will it sweep test (results may not be as linear or on frequency as desired).
Personally I'd just ohm out the transformers and if it is within tolerance recap the vertical properly.
You could also connect the output grid to the heater line via a cap to force the output to sweep some.
