Contrast control mod for FADA (rca 630ts clone)...
https://imgur.com/0pAv0eh this circuit was literally copied from the CTC-16/XL. The same appears in many other RCA color sets with only slight variations. The FADA has a 330 ohm resistor to gnd on the video output now, I see no reason why putting this in won't work as it does in the color sets, (just have to find s 330 ohm pot ), giving it a REAL contrast cont, and not what it has now, an adjustment for RF/IF gain that has an affect on both picture and sound.
So after changing all those bypass caps is your B+ back where it should be in the tuner and video IF circuits?
I can't remember if you showed us your tuner? I'm wondering if it's the standard coil type, and if so have you tried adjusting the local oscillator adjustment for the individual channel you're set to? If it has those adjustments they can be off enough that the fine tuning won't get you best picture and sound. That contrast mod should work. Likely you can even use a 500 ohm pot. However you'll still need to set the rf/if gain for best operation as there is no AGC in this set. But you'll at least have separate gain control over video. |
The voltages are up a bit more to where they should be, it seems that the voltages shown on the riders (& rca 630ts service manual docs ) are misleading, after looking at it for some time, it hit me, how can the voltage on the plate of the 1st IF tube be @ 135v, if the source bias is 135v, going through 3 150 ohm resistors and 1 1k one? It can't be... It must be wrong. Sams shows it to be 95v ![]() And sams shows the (135v) to be 117v.. :/ mine are now very close to that, so I guess the voltage was mostly OK to start with. But still, when I tried to go “by the book” to adjust the 1st if, it did not work right. 1) remove osc tube, did that... 2) DC probe at junction of R40-R41, adjust “contrast” to -3 volts, leave it there. This did not work, it cut off all input from tuner/if , no input defection at all, had to take it up to -1.2 to get it to do anything, and when I did try at that point, it ended up worse than when I started. ![]() It was this point I replaced the WHITE waxy caps, and re-adjusted 1st IF visually, to get to where I am now.
https://i.imgur.com/gBixele.jpg there is a point E, that they suggest feeding in a signal into when alignment it REALLY bad, it's on the far end of the mixer coil stack in the tuner, and feeds into 1st IF. I have found very few resistors bad above 1k ( just a few), but so far EVERY ONE, of the 150 ohms has been bad by 60%-190%, and there are 3 in the tuner ![]() but I really dread pulling it out to replace them.
