#46
What size of resistor should I use if I were to replace the old selenium with a 1n4007 diode?
#47
I made several modifications to my SG-8 to see if I could improve the modulation, etc., including adding a tube. I won't go into all I did, it was mostly experimentation and probably not worth it. |
#48
About that 2420 counter, since it is capable of high accuracy there are a few things you should understand about frequency counters.
The oven crystal oscillator is very stable, however there is an adjustment, a calibration, that is critical so that the display is as accurate as it can be. The oscillator is capable of staying on frequency within better than 1 ppm (one part per million) that is 0.0001 %, much better than any voltage, current or resistance meter measurement. You need that much accuracy if all 8 digits of the display will mean anything. However if the crystal oscillation is only calibrated to an accuracy of, say, 0.1% then the display will be off that much. So the calibration needs to be checked from time to time against a frequency source of even more accuracy. One way is by using super accurate frequency radio broadcasts from stations like WWV and WWVH. More modern methods use GPS managed frequency standards. Last edited by Notimetolooz; 04-23-2020 at 12:06 PM. |
#50
#51
I got the selenium rectifier replaced with a 1N4007 Diode in the Heathkit signal generator.
Picture of the repair is shown below. |
#52
One way is to tune in WWV at 10MHz using a receiver with an S-meter and zero beating with the crystal oscillator output. Anyway that would be something for another thread. |
#53
Zero beating: ever run 2 am radios at once and tune 1 through the band and find a point where they both squeal despite not having touched the one you weren't tuning? That's the local osc zero beating with the osc or station of the other set... In Toulouses example you would tune the Chrystal osc to the frequency of the station and listen for the zero beat then tune for minimum signal on the S-meter (exact frequency zero beat).
#55
#56
#57
#58
Looks to me like the diode is in backwards....
#59
OK so I got my parts in to get my signal generator fixed up the rest of the way (BNC Jacks and a new set of cables for it so I could hook it up to a radio), and I got it all wired up and I went to test it out on an old Zenith Royal 500 Transistor Radio I had laying around and I couldn't get the signal generator to do anything, it wouldn't put out a tone or a signal to the radio or anything, I'm assuming with a transistor radio you don't need a capacitor inline with the test leads like you do an AC powered set.
Also I got tons of line interference through the signal generator similar to the line interference I said I had been getting on my radios. I had my test probes hooked up the RF output jack which I'm assuming that's the hookup I was supposed to use to test the generator out on the radio. any ideas as to what the problem could be? |
#60
You were right it was in wrong, just shortly after I read your comment and I was trying to test it out on an old Zenith Transistor radio I have and I heard a "Pop" noise and I checked it out and sure enough the filter cap that was attached to the diode had vented, thankfully i had a 22 MFD 160 VDC electrolytic in my stash that I was able to replace the vented cap with and now its fine, although I found out that apparently my Zenith radio was way out of adjustment because the 455 kHz IF tone couldn't be heard until around 600 kHz on the radio dial rather than at the end of the dial.
