there's a i.c by the tuner that controls it. that i.c is bad i cant remember what it is called post a pic of the chassis and i could tell you where it is at.
Looks like the AFT is bad so the set isnt stopping tuning.
Try easy first. Go into menus & set the band to "AIR" & the AFT to "NORMAL". See if that helps. After that a chassis pix may help. You can also lightly tap around the tuner, micro & jungle IC & maybe get lucky with a cold joint. 73 Zeno ![]() LFOD ! |
Pictures of the chassis. I also checked for cold soldier joints didn't find any. The TV is set to antenna mode and haven't found a way to change the AFT.
Under the antenna input there is an area on the PCB that looks
greenish. Also the input looks rusty. Anyhows clean up that green mung with a brush & 91% isopropyl alcohol & a brush & try when dried. Looks like water damage... 73 Zeno ![]() LFOD ! |
