Old 07-01-2020, 04:24 PM
Originally Posted by Penthode View Post
I have been silent the last couple of days. I estimate the set has 75 hours and the electrolytics are fine.
I take exception to the comment Tom made. If the capacitor has sat unused for 60 years, the reforming takes hours. It is an electrolysis process you cannot hurry. In this case the capacitors as would be expected would initially test an almost dead short because in the sixty years the dielectric would have disappeared. That is why even applying a Variac is murdering the capacitors. The key is a gradual process that will take about 24 hours.
I limit the current to no more than 5mA at the start. By the time the 450v was reached, the leakage was about 200uA at full rated voltage. Then test capacity and if it is within 20% of the rated value, it is good to go. The important thing is patience.
So I dug up the crusty old space Fada 630TS clone chassis I had and removed two electrolytics. This set sat in a shed for years and the cabinet was shards. The chassis had a lot of rust and the capacitor were pretty grubby when I removed them. There appears to be a date code which suggest the capacitors were made within a week of each other in August 1947.
I put them onto the Sprague TO-6 capacitor analyser power supply to reform them. After 24 hours each of them reached filled rated voltage with a leakage current for each section below 100uA. And tested capacity and all were within 10%. I have never won a lottery and I do not think this is sheer luck. The success is patience and not using the Variac!!
I am going to punish one of these capacitors by running them at and for good measure 5 to 10% above rated maximum voltage to see if I can get it to fail. The other I will keep it at maximum rated 450 volts and then dissect it. Certainly we should not expect to see a picture similar the Banderson's which was apparently insufficiently reformed before applying normal operating voltages.
Here are the candidates. And remember, this is not one off's or luck. I am finding a consistency here.
The ones that the leakage didn't drop fast on got replaced with new capacitors... meaning some potentially reformable caps got changed.... despite that the best of the original caps still eventually failed. If the ones that don't have measurable leakage on my C3 from the beginning are going bad then the ones that were leaking sure as hell are not going to last.
