"Before that, those big American engines that we now consider 'weak' were often making hundreds of horsepower, sometimes 1 per cubic inch. They were made weak to meet emissions standards."
I think it was Super Chevy that dyno'd a prestine version of the supposed "monster '70 Chevelle LS what that everyone brags about how it made more horsepower than GM would admit to. 288 HP at the rear. That's barely an entry level high HP car these days. What "killed" horsepower ratings in the 70's was the feds clamped down on car makers basically advertising whatever number they wanted. It was the same thing they did with stereo equipment. Then you added emissons regulations later on, which the big three figured if they moaned enough, it'd go away. It didn't, and the Japanese ate their lunch. |
The automotive world would be a vastly better place if government had kept it's damn nose out and let the market drive the industry the right direction.
Heh I didn't even know there was a Ford 250ci I-6, and at 88 HP that is abysmal. I think the 223 in my '59 custom has more than that, It allegedly has 140hp (at a pretty high rpm) but I have a hard time believing that.
Fixed that for you.
That statement isn't broken in either form we've written it...
https://www.hotrod.com/articles/ccrp...-engine-build/ |
All in all, the manifolds were WAY more easygoing on this project than I expected.
I expected a lot of seized bolts, instead I found everything finger-tight. Even when there was studs they were loose in the head AND on the nut. The rearmost one to the firewall was even completely missing. I replaced both with bolts and their special washers salvaged from another Eagle. Though to be honest, torquing them was not as fun. It wanted 26 foot pounds each and you could only get to them with a socket U-joint, so I put them all in at 15 and we'll see how that lasts. The EGR tube on the last eagle I salvaged from was seized on pretty tight and had to be cut off. This one, again was easy to crack the threads on. Bolts on the electric heater? No problem! Even the EGR was fine. I did however notice that I was missing an exhaust manifold gasket. I assumed that this was someone previous neglecting to install it but no, that was normal. The gasket kit I ordered made sure to note that while one is included with the kit, finding manifolds without an existing gasket is perfectly normal. Man with how loose everything was this probably explains why this car ticked like a sewing machine so much. |
