Tom has a good start. A good running set without any signal should
give you strong snow & a nice water fall of audio noise. AGC can be substituted with a little bias box. AGC problems were quite rare. almost always IF problem gives bad or no snow & washed out pix. I would NOT consider IF alignment at this point & if you get there replace ALL IF tubes with brand name NOS tubes first. The 4.5 & 41.25 ( IIRC) can be touched up after the set is strong. Just flag your diddle stick so you can go back. 73 Zeno ![]() LFOD ! BTW if you have an IF generator you can walk through the IF stages. Another great little tool is a tuner subber. Strip a click tuner out of a junk solid state set. Give it B+ & a voltage divider for AGC. Short the AFT line to ground. All works on batteries OR get one off Ebay ! |
