Old 08-30-2020, 08:36 PM
This weekend was just more odds and ends work, mainly tightening hoses and oh, fitting the instrument package.
When I was working on the car I added a T-point on the port for the oil pressure switch to add an electronic pressure sender and on the intake manifold replaced the single vacuum port with a dual and plugged it off temporarily. Today I pulled out a box of parts I salvaged from a donor car which had the full package. The pressure sender, the wire and hose harness and bulkhead plug and the console package itself. The idea is you knock out one of the ports int he firewall, route the harness through, everything just plugs into awaiting connectors and the package fits around the automatic shifter.
Initially it did all work great, then after a few hours the oil pressure reading dropped off and I was able to determine that internally a seal had failed and it flooded with oil, so a new sender will have to be purchased. Again, they seem to be really simple devices used by a number of manufacturers so another one will be readily available.
My new hurdle however is this interferes with the mounting bracket I fabricated for the car phone and the satellite radio controller, so I will need to fabricate something new to fit in its place.
