Old 01-21-2021, 11:55 AM
Originally Posted by rca21d645 View Post
Is the 12LP4A a common tube, would it be possible to find someone willing to sell one on here?
All you can do is ask in the classified area, and hope, and you do not have to limit yourself to a 12LP4A exactly, if you find a 12LP4, ( same CRT, but without the gray face ) you could use that, or some other compatible one, for example a 12KP4 will work, just leave off the ion trap, I'm sure there are others that can work as well.
Also, when I was bringing up my FADA, I did not want to risk hurting my 12LP4, so I used a 8YP4 Test CRT that I got from ETM, not exactly the right one to use, but it worked for me with some minor mods!
you can see it all here :p
http://videokarma.org/showthread.php?t=272325
